Dylly
Ok, my bad. Sorry Dylly, I was thinking that with a larger/more efficient turbo I could theoretically move more volume and mass. Here me out on this, so you know where I was/am coming from. Air compresses and I was figuring that with a given volume (6.5), the gmx could hypothetically push twice the air volume. And a larger volume could be realized
by a larger turbo pushing (again hypothetically), say three times the volume. Keeping in mind air compresses. What I don't know is at what point the air can no longer be compressed. That's where i was goin.
Owww, my head hurts now...
I know what youre saying. Bigger turbo equals higher attainable boost numbers which is correct if your engine can spin/ compress air with said turbo.... the gmx becomes a grenade where larger holsets are most efficient.
Also theorerically you could compress air infinitely high... turbo selection gets really tricky because of this.. you can make as much boost as you want as long as there is enough fuel to spool your selected turbo... and thats why we steer away from the gmx toward spexific models... i must thank the members for all their r&d with the tested turbos so far.
