hx 35 downpipe on 6.5
ohh sorry i got bit confused somehow. i can buy the fitting at the hardware store down the road i bet. now i have to get the piece to bolt up to my downpipe
If you follow the link I mentioned, you can get the specifications. Basically it adapts standard threads on one end (which will be female)to metric on the other end(male end into the turbo). I'm making my own DP adapter. But then my exhaust is more then a little different. Made my own set up to include a dual 4" in dual 4"out muffler.
yeah i was actually going to write the specifications down and head over in the morning. i wish i could make my own dp adapter. if i had a welder again lol
I sure would like to see pics of that setup!
Ok so I finally got around to pictures of this 4" exhaust system. Starts as a 3" DP elbow. Then it bells into 4"right at the frame. Under the cab and split to two 4".P1014364.jpg
The right exit is pretty simple so I didn't photo it. but the other side is a different story.P1014368.jpg
Big turn downs out each side and a full rear shot.
Sound good, spools very fast, and low noise in the cab.
Hey Tanman good eye, but that is with the air bags all the way down. It took about three months to get it fit just right. No bumps, rattles or squeaks. At least from the exhaust. Vanman I've got six V shaped baffles (3 from the to 3 from the bottom). They alternate one up then one down.
