ron993
I am new here and usually hang out on the Hummer forum. I just did a complete rebuild of the cooling system on my H1 and am now getting a P0216 code with the first start of the day. I can clear the code and it will not come back until the truck has completely cooled off. Below is what I have replaced:
Leroy's timing gears
fluid dampener harmonic balancer
leroys crank pulley
new alternator
new vacuum pump
new water pump
new power steering pump
leroys bypass restrictor fitting
new ron davis radiator and tri-cooler
new crankshaft position sensor
The truck has 68,500 miles on it, and has a new PMD and I have already swapped in the old PMD that i was running before
leroys crank pulley
new alternator
new vacuum pump
new water pump
