I just happen to have a new order of FRB5's coming in about a week
If it is fresh out the box I imagine it might do that, per OEM manual it is supposed to be 28gph, if doing any HP above stock I highly recommend upgrade to a FTB & Walbro upgrade http://www.thetruckstop.us/forum/showthread.php?572-Feed-The-Beast-Part-I-amp-Part-II-Improve-fuel-to-IP, with pre-filtration to keep crud out the pump which wears pump "innards" over time reducing output underload, IMO the only test worthwhile is a test under loaded condition to know lift pump health http://www.thetruckstop.us/forum/showthread.php?6872-Lift-Pumps-amp-OPS-operation-and-troubleshooting30 GPH free flow to be exact. I used to have a floscan fuel flow meter and I checked one, flowed exactly 30GPH free flow. And flow drops off RAPIDLY if you put it under any pressure.
6.2 turbo did you route a LP bypass? I almost bought a holley blue last night for under 20 dollars + shipping but then I was reminded how noisy they can be. A friend of mine has one. If I wasn't such a tight wad Id probably buy the FRB5 and be done with it but I'll more than likely end up going with the Holley blue and try to quiet it down a bit, the engines already loud eh?
Thanks for everyone's 0.2¢
Well you guys did it, talked me out of buying a cheap used holley blue. Which is probably for the better ha. I would love to have a FRB5 for the durability but the price vs specs doesn't add up for me unless I find a used one which is impossible! I have narrowed it down between two:
Mallory 4140
Free Flow Rate:140 gph
Maximum Pressure: 12 psi
I have already sent one of these back for warranty from seal failure. Although it was the alcohol rated for Biodiesel and the 240 GPH version. Fairly quiet pump.
or
Carter Universal Rotary Vane
Free Flow Rate: 100 gph
Maximum Pressure: 8 psi
This pump has an internal screen and fuel cools the motor. Results in a steady amount of visible bubbles in the fuel. Brushes exposed to fuel do not like Biodiesel. Recall up to 5% biodiesel doesn't even need a label at the pump. Pump started making noise then would run slow in retirement used as a transfer pump. Noisy pump. Used on DB2 with no issues till the LP failed.
The only thing I'm not a fan of is the max pressure of 8 psi with the Carter and the new price of the Mallory (I'd get a used one).
I can't say I wanna spend the money on a new carter either
There is also a chance I'll find one at the junk yard off a medium or heavy duty truck although I bet most of them are probably mechanical for the Detroit and CAT engines.
I bought 2 frb5s a couple yrs ago when frc10 became big. Paid $20 for one and 60 for the other (cam with barbs and a rebuild kit)
