Sheanster27
- Messages
- 14
- Reaction score
- 28
Yes I have a block and a fully stock rolling assembly and stock 98 heads with no cracks that I want to port and open up and biger valves but idk if this will cause major cracking issues and cause leaks I want to put optimizer heads on but at 1200 per head I think stock heads opened up is worth a shot in my opinion idk what do you guys think and the block is going to get a girdle and as much reinforcement help as I can put into the block and bottom end maybe even concrete in the block 3/4 full so I can make it even stronger I will be running water injection to help cool combustion down even more hoping to squeeze winter cooler in with everything elts if I can make it all fit lol!!
