Will L.
Each trip has a little adventure. Hopefully that’s enough for this one.
Yeah...I saw a semi jack knifed in a ditch with the driver outside inspecting, I immediately slowed down (was literally only doing 60) and even then it still did a Lil zig-zag. I called it a night right then and there, currently in a hotel right now.Looking good. drive safe out there on those icy roads.
That started quite easy.Made it to Wisconsin, currently headed to Milwaukee, though i stopped over at Madison.
I literally just filled up now, from Fairmont to Madison, these are the stats
From Milwaukee ill go on to Chicago, honestly cant wait, got many head nods and questions when i rolled up in this wherever i went, hopefully things keep going smoothly
Odometer: 290289
So much salt in MN, i desperately need to wash it this morning.That started quite easy.
I hope where ever You land that they use no car remover on the roads.
Just send that old beast over to Me, I’ll keep it safe from all them metal eating cancerous components.So much salt in MN, i desperately need to wash it this morning.
NY does use salt, ill be forced to get it undercoated, doesnt help that im right there by the coast, the sea salt will EAT it.
(Pic unrelated, Milwaukee is pretty nice. Next stop is Chicago)
I was wondering if it is that temperature probe from the back of the RH cylinder head that has the wire terminal broke off of.I'm still wondering why your glow plug light cycles on and off with the key on. to me something isn't right like maybe the GP controller is tripping. Maybe @Will L. can provide some info on that.
Seems to.me, I had an issue there on the 1989. That unplugging that sensor told the truck it was cold and let things work right until something was fixed. There's probably a thread about it on.one of the forums.I was wondering if it is that temperature probe from the back of the RH cylinder head that has the wire terminal broke off of.
I tried to actually, the end of the wire is distorted since its been against the motor block (heat just melted/deformed it). Couldnt even get the wire back in the sensor if i wanted toDid you connect them & try it?
I was thinking it worked the other way on the 1989. That, if you pulled the plug, it would cycle longer.Yes- that rear temperature sensor with the two wires- this is its job:
1. Tells glow controller how long to run
2. Tells db2 to advance timing for easier start and get fuel in the cylinder sooner since it all isn’t burning away yet.
3. Tells throttle advance solenoid to hold the idle slightly higher.
How it actually works is temperature change alters ohms.
If you didn’t change that sensor yet- that explains a TON. The normal operation is those two wires go from no connection to partial connection to 100% connection.
It WILL NOT HURT to try a jumper wire for cold starts.
In the oldest 6.2 there was a temperature inhibiting method that when it we t bad you lost function of glow plugs completely iirc that could be the case here. But bypassing the temperature switch that broke- I am 90% sure you jumper them together to force a cold start- but it is possible it’s a be other way around.
What ya do is jumper the two wires in the harness with a short piece of scrap wire, 12awg preferably. And if you have a couple male spade connectors- crimp them on and you can plug them in. Then start the truck. Once it’s up to 160° unplug the jumper wire. You should see the difference INSTANTLY by glow plugs cycling on longer.
