GM Guy
Manual Trans. 2WD Enthusiast
why the crunched filter sucking hot underhood air?
otherwise it looks good!
Lol I tripped over it in my garage, it was brand new. Not sure what else to do with the intake
I stuck my battery over the fender but its only temporary till I figured out what to do with my intake. Its only secured with a pull strap cause I didnt have time to come up with a mounting solution. I like your other pics Jorge with the double 90 elbows. Did that bump the battery terminal pretty good?Yeah you need an airbox like the k47. Look at my avatar pic, you can do the same considering you already relocated the battery. I used a section of 4" dryer vent hose to plumb from the opening behind the signal light to the airbox opening, worked great.
Where can I find the 1" shorter belt? The stock is 101" and the smallest I've found is 100.5"Remove it and install a 1 inch shorter serpentine belt, that's it.
That will work. I'll dig up the part number I used tomorrow.
Until the injectors go out,![]()
I've found factory injectors for $1200, yea quite expensive but I'm in a much newer truck now.
