well I changed it in about 40 minutes just tinkering around and going to the barn for tools. And I did put the cover back on. I had to take the ECM out and there were two screws that were holding the ECM tray in that needed to come loose for the cover to come off. I also had to take the left screw out that came in from the top of the tray and loosen the right screw so the tray would rotate out of the way of the cover. One pointer is that the screw hole where the screw with the ground lug on it goes is made smaller than the screw so you will cut into the metal housing when you screw it in, it's easier to run that screw in there the first time before you stick the blower up in there. I even ran that screw in a little crossways pointing up so I could get the socket on it easier once I stuck the blower up in there. Overall not too bad, I'm sure I could do the next one a lot quicker.
