JayTheCPA
The BatMoWheel and Wicked Wheel are TWO COMPLETELY DIFFERENT WHEEL DESIGNS.
Yes, and as Ferm mentioned, they both go after the same symptom: surging. And also agree that, No, they are not copies of each other as each was independently developed.
Not familiar with the other applications in Dodge & GM, but the Batmo & Wicked came about from when folks upgraded their intake and exhaust (but not the turbo) which let the engine breath easier, but the system as a whole was out of balance with not enough pressure on the turbine side to drive the compressor when the engine was under load. Purpose of the Batmo & Wicked wheel is to put the OE Garrett's .85 A/R turbo back in harmony (after an exhaust and / or intake upgrade) which also gives a second effect benefit of better efficiency and power. Most of the 7.3'ers see the Bat & Wicked for what they are and decide whether they want to band-aid the restrictive .85 A/R turbo, or upgrade to a 1.0 A/R which is the better solution for that setup. Please do not get me wrong, the Batmo & Wicked wheels are great products if all somebody wants to do is prevent surging and get a little more 'punch' out of the OE 7.3's turbo.
In reading over the vendor's commentary on the benefits of the billet wheel, there were disclaimers on the need to re-balance the turbo and that the higher HP levels were only possible after a *lot* of other things occurred in tandem. In the end, the Billet wheel might prove a good product for the GM-X turbo, but the questions I have are whether this will throw the system out of balance, call for other secondary upgrades, and just how much of a power / efficiency it provides if somebody only installs it and *no* other change.
But then again, experimentation is why the bunch of us are here . . . :hihi:
