TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
Hi guys,
You have been following my saga http://www.thetruckstop.us/forum/showthread.php?43078-So-I-m-minding-my-own-business-and-I-get-a-code-88-error-TDC-Offset-Error regarding getting a TDC Offset Error.
One of our valued members (MissyGoodWrench) suggested that the Crank Position Sensor (CPS) might be malfunctioning. I'm looking at possibly replacing it.
OK, I think I see the CPS down behind the power steering pump. It appears the Factory Service Manual (See attachment) calls for the power steering pump to be removed... Is that truly necessary? It's tight, but I can see how you can get in there and pop the bolt out and then wrestle the sensor out.. it doesn't look like the power steering pump is attached to the CPS in any way...
Thanks,
Rob
Thanks,
Rob
