fastjohnny
they are empty
Got it done. Pretty easy, but a bit involved.
Thanks for all the info here guys. Problem now I have this extra mystery knob on my dash. I'm going to tell my buddies it's a self destruct switch.
Something tells me my mpg may be affected with this mod.:thumbsup:
Check with your ScanTech, with mine on the idle mm3 doesn't change much from high to low. Leo
My MPG has gone down, because I let it Idle more. More run time with NO miles. But its worth it, with a nice warmer truck in the winter and a chilly cool truck in the summer. I find myself carrying two keys to lock the truck while it runs.
I can pull my keys out while its running, its called the wore out key mod.![]()
:haha:
Sweet, we should add that to the sticky section!):h
Good job Gerald, how do you like it?
:smile5: I think it's super sweet.
Can't wait to actually use it...
One question though. Is it a good thing having the engine rev when it's cold out? Seems a bit aggressive.![]()
I wonder if there is a way to engauge the high idle using a spare button on a remote car starter as well as with a dash mounted toggle. Then you could start the truck, let it sit for a minute, and then engauge high idle without ever leaving the house.
Bill
Bill
From what I am reading the early ones (obdI) has only one high idle setting?
Getting ready to do mine and would like the option for a little higher than 1070 RPM's. Mainly for winch use or jump starting.
