Will L.
Why is there little data collected and available? Too soon.
We're all Chevy guys here- how's about this example: the 70's and 80's Chevy/GMC trucks that from the dumb design of external frame fuel tanks killed over 600 people. Why wasn't the info available in the 70's too soon. But in the 80's it was WAIT FOR IT too soon.it was in the 90's the ntsa figured that was way too many people, way more death per truck rate compared any other competitors.
More GM- 1999 a 4.9 billion dollar lawsuit settles. From a 1993 wreck that led the way of it and earlier wrecks in a 1979 Malibu.
Too soon. Wait for it, it's coming.
If you talked to GM would they say there's a problem? The Ivey memo says $2.40 per car is value of a life. Safety changes beyond that amount were not implemented. (Don't worry, inflation puts us at $13-$14 today)
So you start making a new coolant and the company is growing fast, so is your whole industry of new coolants. Then something happens- you find out people are getting badly burned, some to death even from your product. You close up shop, give all the $ away to the victims and start flipping burgers, ooorrrr, you sellmas much as you can in the mean time...
Which would you choose?
There have been and are more pending lawsuits against waterless coolant companies. (Hint- it's like I am purposely not mentioning name brands here for a reason).
Your a big boy, drive a ford pinto if you want - why does everyone know the pinto referance when GM had 3 models worse for the same problem? Weird.
Anyways, drive a pinto, with waterless coolant and propane in the a/c system, with black mambas slithering in the back seat if you choose, just be aware of the possible dangers.
If people want to spend hundreds of dollars more than they need to in order to implement the cooling fixes they need, they can. I just try to share my knowledge in case it can help someone.
