Big T
Took the wife snipping at me for leaving the HID headlight boxes on the center island kitchen counter for months to finally get me to install the HIDs on my '99. Previous attempts/tests resulted in no lights. As suggested here, I reversed polarity on the plug at the ballast and voila!
Major PITA finding a location to mount the ballasts. I used the side bolt of the battery tray for the bottom mount and drilled a hole though the inside fender wall and used a sheet metal screw for the top mount. So I have HID Lo beams now. The kits only came with one harness each and one was needed for each side, so I need two more harnesses for the Hi beams. I will also need to modify the plug lengths significantly to allow a mounting of the Hi beam ballasts further back in the engine compartment. I suspect I will also need two "all 4 on Hi" relay kits, one for each side, to do that mod.
I got a good feel for what the HIDs can do vs the halogens on the approach to our place at Big Bear Lake. No street lights and the HIDs Lo beams were impressive. Switch to halogen Hi beams and what a major disappointment. Now I know that I have to get the HID Hi beams in place. Again, just a major PITA finding a place to mount the ballasts and definitely will have to get creative with the wiring for Hi ballasts and "All 4 on Hi".
