HELP!
New Tank, Sending Unit, Fuel Lines from tank to LP,Lift Pump, Fuel Filter and a pressure gauge mounted by the Oil Fill Tube! Fuel pressure with key on is almost 11 psi and running is 7 1/2 psi! The truck runs quieter and pulls better than it did when I bought it in July of 2000! THANK YOU to ALL who replied and helped me with this problem. It is great to know there are other people who will share the knowledge. Again, THANK YOU! Keith
Hopefully I won't have any more problems for a while so my next purchase can be a triple gauge pod with egt,boost and trans. temp and a stand alone in cab fuel pressure gauge instead of repair parts!
Sounds good, some nice pressure you have.
Im installing my electric fuel pressure gauge in cab this weekend.
Buddy take a lot of pix please, it would make a great write up. I sure am interested in doing the same shortly with an electric one also for simplicity. Even though its pretty straight forward, seeing your setup and how you T in the sender before the IP will help my install, and others too I'm sure.
The first mod to my truck is gauges. I want Fuel pressure, EGT, Boost, Trans temp, and rear end temp.
I would like to see install pictures on your fuel gauge. :thumbsup:
