have one belt that runs everything ..it goes across water pump,ps,crank,cam,ac,and etc..can it run with no belt on it at all?
We are dealing with a Duramax engine. The water pump is gear driven and NOT fun to change. The fan shaft is just an idler bearing. So you will have water flow with the belt off.
Will has a good idea. I posted above how to check the alternator connections. So you are testing the battery charge wire and the wires in the alt plug. How did the test turn out?
