Will L.
Adding center mount turbo, hummer uses same gm6 as a van.
The oil pump drive on the n/a 6.5 has a sensor on top for generating a signal to the trans control module (no PCM).
My donor engine has crank sensor, can I use this for the signal and if so how? Crank sensor has 3 wire, oil pump drive has 2 wire. Thanks
