so if i take the harness that came with my relocation kit, chop it in half, and lengthen the wire it will be fine? does the pmd ground using the bolts that hold it down? its already moved off the IP. also will water be a problem for the PMD being mounted in the bumper? or should i mount it in the cab with a little fan cooling it some way?
