fastjohnny
My 'burb has always had poor front heat output. This morning, I spent a little time to further try to get an understanding of this. The rear heat output is fairly good. The front heat will do fair to OK if on recirc, but if on fresh air, it is barely warm, more of a cool-but not cold output. This is through floor heat, defrost, or middle vents. The heater hoses seem hot. The engine temp is not much past 160, prob 175 or so, driving 60-70 mph, with ambient outdoor temps mid 30's. I have never checked the thermostats to see what ones are in there. Also, when I've been running with a plow, and had engine temps significantly higher, it did not provide any better heat in through the front heater.
It's been a long time since I've been into one of these heaters, is there a blend door opening too much???
Other ideas??
Thanks in advance.
Other ideas??
Thanks in advance.
