Help needed with my 96 suburban
just some 30w non detergent oil, use to run ash-less two stroke in my 6.2 & 6.5 mechanical but have read it can mess with the optical sensor in this one
Do you know when the 100K life injectors were last rebuilt?
"NOT SAYING THIS IS YOUR PROBLEM" But I've seen a harness issue give that 'no throttle response' the harness at fault was in the passenger foot well it hangs down so when a passenger stretches out by placing their feet on the harness it pulls at connectors on PCM the fix was to push pin all the way back into their slots and strap the harness with a insulated clamp to side of blower motor case to eliminate the hanging and ply.
