gsantoyo83
Hi everyone I have a problem on my 2003 GMC sierra SLE 5.3 rear wheel bearings. I am installing new rear wheel bearing due to the old bearing been noisy and a wobble. I desided to replace the other wheel bearing as well the bearing where hard to pull out one even snap a side of the lip bearing housing, so know am stuck. The new wheel bearings just slide in and out they don't stay in place I know they should be press in but the bearings are loose. I check the old bearings whit the new one there the same size the old bearings have this burn marks I also had metal shavings inside the differential cover had tooth marks i clean every thing inside the differential so now am stuck. what could be wrong? :???:
A little history about a month a go i had a small accident the made my truck swirl and made a complete 360 i ended with the rear wheel hitting some rocks which shoock the rear wheel hard I drove the the like that started to hear whining noise and the wobble in the wheel.
