BLACK RHINO
Test Pilot. You buy it I break it..
Driving my 03 3500 too work. Starts running real rough and spewing white smoke. Got it off the road re started it once but was running real rough and surging. Towed it back home and now it just rolls over no fire at all. Ijectors seem too be fine. ( Unplugged them and checked the resistance in them. Was in spec on all 6.) When I try too start it only gives 6 volts too cylinders 1-3. 12+ too 4-6. Disabled the preheater and it does fire on ether but won't catch. Got two DTC's P2146 and P2149. Transfer pump seems too work fine, And all ready did the factory recall on that so am sure that is fine. Down too must be A ECM or the CP-3 Fuel pump. Anyone know exactly what I need????? Any help would be greatly appreciated...:mad2: Thanks for your time..
Rhino.
Rhino.
