ak diesel driver
6.5 driver
Loosen the fuel cap and see if that helps
I’ll check the cap. Wasn’t aware the pump return is clear, will check that too. Thanks.Yup, loosen the cap is next.
Any bubbles in the clear ip return line? That can be air intrusion or if tank /cap isn’t venting the fuel under vacuum will self aerate (boil while still cold) which is amazingly hard on the ip, and can ruin a brand new ip in a week if bad enough. This will show up as no pressure if the gauge is tapped at the ip inlet. If pressure is present and bubbles then it is simple air intrusion.
