okay hello you all, I need some serious help. I have a wonderful 96 diesel 2500 sub. I love it it fits us perfectly but has had some interesting issues lately... I am attaching the check list and am filling it out the best I can, i need some help, I do not want to want to sell this truck!
Okay so the truck will be running just find and will stall out of no where it will it usually recranks and runs but occassionally you will put the key in and it won't make a sound. The glow plug light won't come on and it is quiet. My husband has tried removing the batery cable (neg on both sides) and allowing the computer to reset, we hook the cables back up and after a few minutes of them being hooked up it cranks. We haven't done this to know if it is just a chance cranking or if removing the cables actually help it out... This is variable, it seems electrical but hubby is frustrated and not sure what to do next... HELP PLEASE!
1. Does the engine crank, or 'turn over'? yes when it isn't having a problem, quiet when it is having and"issue"
1a. Does the engine start and run? beautifully when it does turn over
1a1. If the engine does not start - Crack injector line: do you have fuel? Yes
1b. Do you have a Wait To Start Light & the amount of time (seconds) lit. No
1c. Ambient Condition (temperature outside indicate F or C) ?50 F
1d. Engine Cranking speed (if you have an accurate tachometer). ?
1e. Are you experiencing stalling? Yes
1f. If Stalling, describe (upon startup only, down the road, hit a bump etc) hmm, about 5 minutes after start up
1g. If Stalling, do you notice loss of dash or instruments? not sure
-note if experiencing stalling,you must indicate PMD location in #24.
1h. Check turbo inlet and air filter for obstructions. Cone filters have lost disk and stopped air to turbo.
1i. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now? yes/no
1.1 Lift pump test - describe results
2. Service Engine Light while running?- off
2a. Service Engine light does glow during start/cranking/bulb check: Yes, but not sure if when the wait to start light isn't coming on if it isn't coming on also
3. Model year 1996
3a. Odometer reading (indicate if in miles or km) 120,000
3b. Miles on major engine components if been replaced (example Injection pump)
3c. Indicate the model number on the Injection pump (starts DS4 or DB2......)
4. Have you scanned for engine codes? (varies by pre/post 96) no
5. List exact results on engine codes:
6. Air Filter condition (visual check) fine
7. Fuel filter condition (freshly changed/condition unknown/mileage since changed) changed within the year
8. Condition of Battery terminal connections (removed, cleaned and tightened) cleaned and tightened
8a. Known condition and age of the batteries. bought withing the last 6 months
8b. Are batteries of differing age or are they a matched set? matching
8c. Condition of Major Grounds. (same drill as batt - removed, cleaned, retightened) not sure
9. Upon cold start, does the radiator hose get hard quickly?
10. Upon cold start, do you have excessive white smoke? smoke yes not a lot
11. Do you have excessive cranking time before the engine starts? no
12. Have you used the block heater, and does this effect engine starting?(only try for starting problems) haven't tried it
13. During hard acceleration, do you have excessive black smoke? no
14. Do you have any unusual exhaust smoke issues? no
15. Turbo check out - ?
16. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit) ?
17. Indicate if you know if it’s a 2500
18. Indicate fuel that you are using: Diesel
18a. If running a VO (Veggie Oil fuel) setup, indicate details of your conversion (homemade, or packaged system)
19. Are you using any fuel additives? If so, please list. none
20. Please indicate geographic region you are in: Alabama
21. Do you have any service history available that might pertain to the problem you are having? have replaced OPS, PMD
22. Please indicate any modifications to the vehicle that might help us diagnose better.
23. Upon unscrewing the fuel cap, do you have a large vacuum formed in the tank? yes
24. Location of PMD/FSD? On the pump/remoted over intake/remoted out of engine bay on a heat sinc (?) and attached to where the turbo cover is, thinking about moving it
24a. If remote mounted, describe wiring harness (homemade or purchased from a vendor?)
24b. Indicate the location and condition of the FSD/IP grounding wire.
25. Are ALL glow plugs in proper working order as per this thread yes
3. Model year 1996
