Mjackson4120
So I have a 93 Chevy suburban 2500 4x4 454 motor 4l80e trans.
Problem no overdrive on the highway. I have replaced solenoids for gears 2&3 and the tcc solenoid changed filter but not fluid. Replaced the brake switch on the brake pedal and the tps sensor which had to be modified to sit right so the the engine would idle normally. All other gears are fine shifts perfectly with plenty of power just can't get that last lock up to stay. It will go into the last gear but only for a couple of min. Any ideas.also can't seem to find it anywhere what should be the idle rpm for that motor?
