Edzzed
the way mine is set up would use more water as it is basically full on or off. I could go the egt route and use water only when egt's rise but it's a fine line where you want water to come on precisely. I went to heaths link and the description he gives is what devilsown does. I too would have gone with heath as he knows his stuff. when you get the kit see if you can read what the nozzles are for flow. mine are stamped. seems no one wants to give up that info. as for tanks any polyethylene tank will work including fuel storage containers. I went with the marine tank as it has a fitting that happened to be a perfect fit. no mess no fuss. and i can still flip my rear seat down although leg room sucks. now that I have a canopy i could install an rv fresh water tank but for my purposes the 5 gallon tank works fine and i do have a spray port on the rv where i can hook up a hose to refill it should i need to. anyhow the short of it is i think you'll be pleased with heaths. Ed
