MrMarty51
My truck has been converted to the 4 bulb 4”x6” headlight system from a 1988-1989 pickup.
I think that with all four bulbs being lit up on the hi and low beam bulbs being ignited all at the same time is taxing to the 30 amp main fuses in the under the hood fuse box when the heater blower and AC is all running at the same time.
When I first got the truck there was one of the fuses blown, but, the PO had also installed a 50 amp fuse in one of the slots and left the other slot to the factory 30 amp fuses, well, this time both fuses burned out, stalling the truck 50 miles from home.
I had two 30 amp fuses along so installed those and the truck was good for the fifty mile drive the rest of the way home.
So now I would like to do the LED conversion to lighten the amperage draw load but I dont know, or understand the differences in the LED bulb systems.
So, from ebay which would be the better unit to convert to ?
1:
2:
ebay.us
OR
3:
1:
4PCS 4x6'' LED Headlights Hi/Lo H4 Lamp For GMC C1500 Suburban G2500 G3500 Van | eBay
Compatible with headlights: H4656/H4651/4651/4652/H4652/H4666/H6545. Also suitable for most of other vehicles such as Toyota 60 80 Series, Chevy /Chevrolet Camaro, Kenworth T800 T400 T600 W900B W900L, Freightliner FLD120 112 FLD, Peterbilt 379 378 357 and other models which need 4x6" rectangular...
ebay.us
2:
Dot 4pcs 4"x6" LED Headlights High Low Beam for Peterbilt 379 Freightliner Truck for sale online | eBay
Find many great new & used options and get the best deals for Dot 4pcs 4"x6" LED Headlights High Low Beam for Peterbilt 379 Freightliner Truck at the best online prices at eBay! Free shipping for many products!
OR
3:
FOR 1988 1989 Chevy K1500 K2500 K3500 4pc 4x6" Headlights Hi/Lo Beam H4651 DOT | eBay
This product is not applicable to FOR 1989 Chevy k3500! Beam Pattern: High & Low Beam. Easy installation: Plug and Play, the headlights are with standard 3-Pin plug (H4 plug). IP67 waterproof rate, special heat sink design for efficient cooling dissipation.
ebay.us
