Brooklyn Tow
9 11 Never Forget
Question:.......Is it possible for upper or lower intake manifold gaskets to allow combustion into the coolant......Can it be anything else except HG, head(s) or cracked block???
Time to pull the crossover off the block. Fill the engine till the water is at the top of the crossover ports on the head. Take off the fan belt. Start the engine and look for bubbles. This (bubbles) will let you know if you have to pull a head and what side to pull. Overheating at idle is an airlock condition and suspect cracked head or blown gaskets.
Will I do any significant damage driving the rig in this condition?
I have zero experience with the cooling tabs but would give them a try.
The best thing would be to pull the heads though.
Honestly if you've never done it (this was my first time pulling heads) it's a bit of a project but you can do it. My only advise is when you do, get a manual for it and keep track of where the fasteners go to. There are TONS of bolts and nuts.Thanks for all the advise guys.....I'll keep you all posted on any developments, good or bad.
David, I know your under the gun (time wise) and the pressure sucks, but Devin and you are pretty skilled wrench turners and your attention to detail is second to NONE.......(I'm a novice at best and seem to fighting more than one issue at this point) I and many others have absolute faith, that you guys will cover all the bases......I'm still pullin for you Brother!
If you use the cooling tabs, get the GM ones as they are an organic material that won't harm any other system. They come as a 5-pack. I've read you should crush them up and stick them in the upper radiator hose.I have zero experience with the cooling tabs but would give them a try.
Mine's at 150,100 right now. :/ I was hoping it would have made it longer, hopefully now it will.Gonna have to Leo, this truck aint going anywhere, it works too hard...(It's the money maker)......Besides this day was comming sooner or later, at least thats the way I see it.
Just didn't think it would be, before the odo saw 150,000 mi.........and the previous 2 owners were big fleet Co. but there PM sucks. God knows how many times they overheated this engine.
