doober
I had the same over fill problem with my transfercase in my 92. I have the nv4500 transmission in it and that uses the gl-5 gear syncromesh fluid. So my transfercase was getting filled up with the gear lube.
Not a big deal to change that seal. I think I just took the rear driveshaft off and the front drive shaft off. I had to cut a wrench in half to get at the top bolt on the transfercase because there wasn't enough room to get the wrench up in there.
Getting it out wasn't that bad. The transfercase is alittle awkward and heavy and putting it back on the shaft was more of struggle. My arms got tired trying to get it back on the splines. The seal was only acouple of bucks. I think I also bought the gasket where the transfercase mounts to the transmission because mine tore in half when I took the transfercase out.
You should be able to tackle this job though. My seal had three hairline cracks in it.
