Brooklyn Tow
9 11 Never Forget
Would a 1998 Harness be the same as a 96?
Plug and play?
Plug and play?
doesn't the Passlock share a small BCM with the EVO system?
Louis, are you in the market for a complete harness? If so, what the hell happened to yours?? I have one from a 98 also if it is something you may be interested in.
-Nick
passlock in the GMT-400's uses a passlock module that hooks to the ignition switch sensors I believe. Which harness is it you are replacing? The underhood harness should be the same, but the dash harness inside will be slightly different as 97+ had passlock whereas 96 didn't. Also I think there was a slight change in how the glow plug system turned teh light on in the cluster in 96 VS 97+.
