So for those that like to be "technical" here is my correspondence with Paul Bennett from Fluiddamper about HBs. You'll need to scroll down to the bottom and read it from the bottom up to be in order.
-----Original Message-----
Sent: Wednesday, April 18, 2012 4:04 PM
To: Paul Bennett
Subject: RE: Fluidampr.com Tech Support Request
Do you mind if I post this on a forum?
Sent: Wednesday, April 18, 2012 11:26 AM
To: Les
The rubber that is inside of the pulley acts more as a torsional spike reducer. This makes sure the belt does not slip or chirp when it's running.
The rubber in the pulley serves as a decoupler mostly, but does not serve much use in reducing engine torsional vibrations. Hope this clears things up.
Paul @ Fluidampr
Sent: Tuesday, April 17, 2012 4:36 PM
To: Paul Bennett
Thanks for the reply. So what would you say the purpose of the rubber in the accessory pulley if for, shock loading??
Sent: Tuesday, April 17, 2012 12:27 PM
To: Les
Les,
Sorry for the delay, I was out of the office for surgery. I am not sure if you called the office or not while I was gone but I'll try my best to answer your question.
The accessory pulley is part of the damper, but it does NOT function in any way to dampen vibrations. Its only purpose is to drive the belts. Like I said in my previous email, some pulleys are removable while some are machined into the housing as 1 unit. The pulleys are machined to strict tolerances as to make sure there will be no wobbling of any sorts.
Hope this helps,
Paul
Sent: Wednesday, April 11, 2012 2:05 AM
To: Paul Bennett
I understand that I need to use my oem pulley but you didn't answer my ?. Is the accessory pulley, which has rubber isolation built into it considered part of the harmonic balancer system?
Sent: Tuesday, April 10, 2012 12:26 PM
To:
Les,
Thank you for contacting Fluidamr's tech support.
Depending on the application/engine, the serpentine belts will vary. Some of our dampers have serpentine/v belt grooves while others do not. Our 6.5 chevy damper does not come with belt grooves, you will use our OEM pulleys/belts on this application. If there is anything else I can help you with please feel free to ask.
Thanks,
Paul @ Fluidampr
[email protected] [mailto:
[email protected]]
Sent: Monday, April 09, 2012 4:54 PM
To: Ivan Snyder; Pete Dandrea; Paul Bennett
Subject: Fluidampr.com Tech Support Request
First Name: Les
Last Name:
Email:
Phone: 907-715-6858
Engine: chevy 6.5 diesel
Comments: was wanting to know if the accessory belt pulley that bolts to the harmonic balancer is considered part of the harmonic balancing system?
