NCadam
so for the lats few months I have been having start up problems after the truck sits for more than 6 hours outside temp dose not seem to matter. i have to crank it for several min to get it to start, I have found that if I give a little push on the gas pedal as im cranking it helps makes me think its losing its prime or something like that. Once i get it to fire it will start fine as long as i dont walk away from it for more than 6 hours..... I do get alot of white smoak out of it on start up but it goes away
here is what i got
96 3500 dually vin f 6.5 turbo with a auto trans
200,000 miles on it
here is a list of what i have replaced in the last 6 months
starter, both batts, fuel filter, air filter, injectors, block heater, glow plugs water pump, thermostat and housing to the dual, 5 blade to 9 blade fan
I have done the lift pump test and I get steady fuel out the hose on the front of the motor and I get fuel out of the release on the fuel filter.
If some one had some imput on this it would be great I have been on many many fourms reading on this and so far the truck stop has the most inteigent people on it thanks and sorry about my spelling
here is what i got
200,000 miles on it
