Will L.
100% you are sucking air. Not a fuel leak. Sucking air in the fuel line somewhere.
It also could be bleeding off through a bad liftpump check valve. But even if the check valve is bad, that can not allow air in the line unless there is a open section of line. So still first fix is new sae30r9 fuel line.
If you have a 100% filled tank and that solves the problem, then it is in the tank. Drop the tank and replace the 20 year old line inside.
If the full tank does not solve it, replace the rubber lines ontop of the tank, and the lines at fuel filter and injection pump.
The best answer is do inside the tank at the same time so that everything is good for the next 15 years.
Now you need to know about fuel pressure. When replacing the fuel line from ffm to ip, install a “T” for the new fuel pressure gauge. I like mechanical gauges, but electric is easier. Max 15 psi gauge so you can read the lower levels accurately.
