great white
My truck has been broken in to once (before I owned it).
Much the same way as probably all the GMT400's have been broken into; jam a screwdriver in between the handle "cassette" and door skin, pop the lock cylinder rod and open the door.
My door skin was bent in the attempt and the handle cassette was snapped (thank you cast aluminum). Both sides. God forbid you actually work for something when you can just steal it.......:skep:
When I bought the truck I replaced them with some spares I had lying around. All is good, handles work again and look good.
But now, I'm living in a very low crime rate area.
Good right?
Nope.
I had to pop down to the local quick-e-mart for a carton of milk today.
As pulled in, there was another GMT400 in the lot with a guy standing next to it.
I pulled in and looked at the guy as I parked.
The little dirty little F'n SOB had a frickin' screwdriver in his hand!
When he saw me looking his way he walked off. A bit later, I saw a different guy leave the store and drive the truck away.
Christmas freakin' day no less....what a F*&^#G A$$&*^E !!!!!!!
Well, long story short, I don't want these "c'mon in" door cassettes on my truck anymore. I'm military and could end up living in Edmonton, Toronto, Victoria, Hallifax, etc at the drop of a hat. All waaaayyy higher crime rate areas than where I am now......
I'm planning some sheet metal work in the somewhat near future so I plan to remove these things and weld in something less thief friendly.
Seems most guys want to use the newer handles like the GMT400 for that flush look, I'm actually thinking of going backwards to move forward.
I'm thinking of grabbing something like a mid 80's Camaro set of handles, skin and all:
Graft it into the area that's a big open square in the GMT400 panels and call it done. GM was even nice enough to make a nice flange to weld the patch panel into (stock lip for the stock "cassette").
The Camaro handles aren't flush:
but they're close to it and a small price to pay for better security.
Anyone have any other suggestions?
Maybe the handles of a 60's car with the external handle?
I'm stuck with aluminum of pot metal no matter what I do, but I can at least minimize the vulnerability of the design with something like the Camaro door skin pieces.
The Kodiak ones aren't an option here. Same/similar problem with ease of break in.
I've also looked at things like "jimmijammers", but I'm not impressed. The thief will still try jamming the screwdriver in, which will F up the door skin and break the handle. I want them to walk up, get confused and walk away.
Sure, they can still break the window, but why bother when there's an easier "pigeon" two rows over in the same parking lot....
PS. My ignition is defeated in a way no one will get it started unless they know how. No switches, no locks, no plugs......
Good right?
Nope.
