FellowTraveler
I would be remix not to point out that the actual stall speed you will get from any converter always increases with modifications that raise peak torque and its rpm.
The converter was designed as a torque multiplier at speed which ceates lots of heat and increases your fuel consumption however; when dealing with the Cummins your peak torque comes in at lower rpm than say the 6.5td so it does not need much torque multiplication at the converter so a low stall makes for a much better DD diesel. Keep in mind if too low a stall it can overwhelm your breaks on stops.....so individuals who have the too low stall just put it in neutral at stops.
