TravelingMan0491
This past week my fuel pressure guage went from being ~1.5 psi to a vacuum of over 20 psi! Figured it might have been the OPS or the lift pump since I had nothing coming out of the air bleed screw on the fuel filter. Gave me a good opportunity to install the OPS extension hose from Leroy's. Luckily I had a spare OPS and lift pump from when I first got my truck about 5 years ago (however they were from SSD... I hate them). Helped for a little bit but the vacuum in the fuel line appeared again. I decided to blow air from my compressor into the line leading to the fuel tank from the line going into the lift pump and was able to get 4 psi for a good while until vacuum appeared again. I decided to drop the tank today and found the following:
Here is a comparison of the cleaned up filter sock and what SSD sold me as their replacement:
This is a good justification to having a fuel pressure guage because I wouldn't have pinpointed the cause of the fishbitig I was experiencing without it. Thanks everyone for your previous posts on removing the fuel tank and blowing air into the lines!
