1995 K2500 HD w/ 6.5. Just installed a Curt below bed gooseneck hitch. Had a gooseneck trailer attached on the hitch, verified it was seated and latched....connected pin into latch. Attached safety chains.
Backed on a 12-13k lbs off road forklift onto beaver tail of trailer and as I was getting up onto the trailer it obviously started pulling up hard on the truck while the back of trailer began to squat. Before I knew it, the whole gooseneck connector was off the ball and up in the air, just dangling around, and only the safety chains were holding the trailer in place and keeping the whole thing from doing a giant wheelie!
With some directions from my dad who was standing nearby, I gently moved the forklift back toward the ramps some to better balance the trailer and keep the latch from slamming down into my truck bed. Then I was able to lock the forklift brakes and back the truck up a bit so the ball was under the hitch again and we put some weight on the front of the trailer to seat it back down and latch it.
Seems the upward force from all that weight on the very back of the trailer was able to just flat out lift the front of the trailer and disconnect the gooseneck from the ball. Something I never would have imagined possible. Anyone ever have this problem? Maybe trailer latch needs replaced or is no good? Ball was correct size at 2-5/16 and was brand new. I can confirm hitch was latched and not sitting overtop of ball.
Anyway made for quite the scare, and now I make sure to put big wood chunks under the trailer to limit the squat on the back of the beaver tail trailer, and haven't had a problem since! Curious to hear if anyone else has had this problem when loading at all.
