ak diesel driver
6.5 driver
You ever seen black marks on dirt. I have it surprised me.
Good point on the fan clutch - since it’s still based on the flow of silicone, I doubt you could turn it off that instantaneously.Exactly. Use it to help build boost before launch and cool during staging then cut to lowest lock up to race? It would be nice if it reacted that fast but unlikely. Maybe Leroy's electric clutch.
I have seen a few trucks with the lowered back end and don't really like the look. I saw one with lifted front, lowered rear, and sets the tailgate open 1/4. Kinda a poser look. Looks like it makes visibility poor. To each his own but not for me. I don't like my truck to sag even when loaded.
My understanding is aggressive open lugs are good for clearing heavy sticky mud. Kinda depends on your dirt. I would think you judge it by how much the tire loads up and ease of clean out???
How about your tie rods? Did you feel a lot of pull steering or bad wobble? I thought ya'll both took off pretty straight with a little squirm at first And how about your new rear end. Don't you like that little positive traction squirm in the back end but hooking with front to pull diagonal too.
You bet! These guys should be in your neck of the woods too - they said they run like 20 races a year in Ohio. Check it out!Dirt drags are alot of fun. Thanks for sharing!
that look is called “the Carolina squat” by the young guys around here in South Carolina. I don’t like it either.
There is a guy that works where I do that has a dodge 2500 with a 6” lift in the front and the back is stock. I asked him about it a while back. I don’t see how he knows where he is going especially at night. It seems like the headlights would be aiming at the stars.
Next time I’m on the same job as him I’ll post a picture of how it looks.
You talking line lock or a trans brake?Line lock it. Stock power can overcome the brakes. Neither are stock on yours. Results with brakes are not guaranteed.
