GMTDscan results
wayneg913
ENGINE SENSORS
Engine run time: 00:00:00
Boost pressure (MAP): 28.4 PSI
Desired EGR: 10.59 PSI
Desired idle: 2325 RPM
EGR pressure: 2.61 PSI
EGR duty cycle: 60.5 %
Engine coolant temp: 127.6 F°
Engine speed: 19 RPM
Glow plug relay feedback: 0 Volts
Glow plug voltage: 5.1 Volts
Ignition voltage: 24.4 Volts
Wastegate duty cycle: 71.9 %
__________________________________________________________________
INFORMATION SENSORS
PCM Calibration ID: 0
Current DTCs: 42
Accel. ped. pos. 1: 0 Volts
Accel. ped. pos. 2: 5.02 Volts
Accel. ped. pos. 3: 5 Volts
Barometric pressure (BARO): 8.69 PSI
Battery voltage: 2.5 Volts
Fuel temperature: 134.2 F°
Intake air temp: 304.3 F°
Throttle position: 0 %
Turbo boost (Calculated): 19.72 PSI
Voltage reference sensor: 0.8 Volts
INJECTION PUMP SENSORS
Actual injection pump timing: 604.12 Deg °
Cam reference missed: 210 Counts
Crank reference missed: 134 Counts
Fuel calibration: 64 Counts
Fuel rate: 9.69 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 0 mm³
Fuel rate - Maximum transient: 41.88 mm³
Fuel rate - Throttle requested: 22.88 mm³
Injection pulse width: 185.04 ms
Injection timing - Measured: 0 Deg °
Injection timing - Desired: 0 Deg °
TDC offset: 36.96 Deg °
Things I don't understand.
Engine run time never moves off of 0.
Engine coolant is always 127.6, even immediately after starting
Engine speed is always 19 rpm
Battery voltage is only 2.5v
Ignition voltage is 24.4v
Actural Injection pump timing is 604.12 degrees (How can it run that way???)
TDCO is 36.96 degrees
I've ordered a remanufactured IP from SSDiesel to address the long injection pulse width.
I've checked the timing marks on the crank-cam gear and they line up.
I've rotated the crank 1 rev and then the IP-cam gears align.
604.12 degrees seems way out of bounds but the truck ran good when it warmed up.
Any ideas on why some numbers are so far from where they should be?
RUN AWAY FROM SS DIESEL!!!!
CANCEL THE ORDER NOW!
DO NOT ACCEPT SHIPMENT!
we can share horror stories later but basically horrible rip off place that almost ever honors any warranty
I bought a reman IP that a feller over here had purchased and it was dome by SSDS, before I need to use that pump, it will be sent over to Quadstar Tuning so John can send it off and get it done right. After reading so many horror stories, and not just from this forum, from every forum out there that has the 6.5 in threads,I would never buy from that outfit.
On the low battery voltage, you have to load test the batteries one at a time.
Even If one is bad, then you have to replace both.
I would not replace the IP yet.
Try to fix the easy stuff first.
As it is, you have been warned about SSD, it has the best marketing hype but never have a good reputation.
Are you using the free version of GMTDScan or the paid version?
The free version have some features disabled.
