Acesneights1
That's what probably did it.
What brand/type are you installing? With starting fluid having been used I would take bk's advice and get the injectors tested, and if they are original then might consider rebuilding them anyway.
Pull the passenger side fender well out. It takes 15 mins. You don't need to remove the batt tray, just unbolt it from the fender well. They come out pretty easy once you finagle them out of the truck.I'm installing Delphi HDS309s... from the looks of it, that's what I'm pulling too. The PO said he had the injectors repaired/replaced, along with a fuel pump (?).
The truck runs good, but I'm just cleaning up some shenanigans. There's the GP issue, some wiring, and a turbo solenoid that was bypassed. So I've got a list of things I'm working on.
I'm not sure how the passenger side plugs get replaced, but I think I have to get a tool at this point. My technique for the last 3 was to pry them out. Peh.
-P
