buddy
Active Member
You shouldnt be concerned about the LP causing hard starts or stalling at idle if its at least flowing. Wheres the PMD?
its in the old PMD
The truck stalled for the first time this morning, but had no issues after I switched the high idle on. I'm going to try and change injectors this weekend, and I'm planning on changing the fuel filter sometime this week - has 8k on it...maybe? ...
Attaboy, Forrest!! Good for you!
I'm glad you got everything running... Thanks to the guys here for the good suggestions and advice! It's all about learning new things and being able to fix our own stuff - with a little help from our friends!
This place rocks!
Sorry for being late to the party, but is your pyro sensor in your downpipe (post-turbo) or in the driver's-side crossover (pre-turbo)? Lots of people put their sensors in the exhausts rather than the manifold, and they work just fine. The 'danger' lines are just at different temps, is all.
Glad you got it worked out. Listening to your video - that starter sounds like it's spinning too slow....either bad batteries, starter or connections. Have you replaced the crossover cable with something bigger yet? When I swapped mine with a NAPA ga. no. 0 wire size it made a big difference - I think the factory crossover cable is 4 or 6 ga.
I don't know if anyone has answered your question regarding hearing the GP relay - yes I can easily hear mine - loud click when it comes on and off.....but I also have the rubber molding removed between the back of the hood and the cowling(for better cooling after shutdown).
