Missy Good Wench
Wild Blonde from Cloud Mt
The little tool is a snap to use.
The split nut is hinged and clamps around the plug and the little "C" device is a shim to allow the add on nut to be used to get the plug far enough out of the hole to be extracted.
As mentioned the RH side is a nasty one but no matter it beats having to remove the head to get the plugs out.
Another note ********************* NOTE**********
Always use neverseaze on the manifold bolt threads when installing them in the head.
These are a rolled thread with a compressed "trilobe" in the root of the thread to cause interference locking.
This keeps the bolts tight but can also make them a bitch to remove when time and rust have worked their dirty deeds.
Never seaze will make removal a much easier task.
Best
MGW
Best
MGW
