My bad - overlooked the question - Diesel oil is high-compression extreme-duty rated for turbocharger service, meaning it is rated for turbocharged EGT's - oil will burn, so it will also evaporate at elevated temperatures (oily fumes, which ignite even easier) - thin oil evaporates at lower temps than thick oil - run thin oil thru the turbocharger cartridge at ~avg650*F and you'll get a lot of oily fumes as it trickles back into the sump - run non-turbo-rated oil thru there and it's Katie, bar the door - thicker oil also seals the piston ring\cylinder wall interface better than thin oil (is why they foolishly suggest pouring motor oil into the cylinder when doing compression-checks, eh) - using thin oil in winter is good because of the overall lower temps than in heat of summer - thus the spec'ed 15W-40 rating of summer oil
And B4 you nay-sayers jump in here with the negatory vibes, think of how much more quickly really-thin Diesel oil...er....fuel....ignites than 40w motor oil, eh - evaporation = volatility...............
FYI (again): you usually will get blue smoke from an oil leak when ingested into the intake system or into the upper cylinder thru worn rings, because normal combustion temps are not hi enuff to ignite the thicker motor oil - get the turbo spooled up and rpms up and EGT's up and it bodes a 'nuther tale, indeed
White (and blue) vapors are resulted when fuel-oil has not reached combustion temps, is exhausted with incomplete ignition - back smoke is resulted from oil that is above combustion temps, has ignited, but oxygen content has been depleted B4 complete burn, is exhausted with incomplete combustion
Try it....you'll like it........................
