May be a dumb question but I know NSBU switches can freeze or ice up and throw all kinds of crazy codes. I have no idea though if they still use those in the newer generation trucks though.
I saw your post just before I left Nick. The more I thought about it the more sense it made after the deep snow I was blasting through. I'll get down there and pull the connector tomorrow and see what it looks like. Probably a good candidate for stuffing the connector full of dielectric grease. It was low +20s today (balmy) so after about 10 key cycles the CEL reset.May be a dumb question but I know NSBU switches can freeze or ice up and throw all kinds of crazy codes. I have no idea though if they still use those in the newer generation trucks though.
my truck set the ''low pressure fuel'' code 2 times yesterday -31 and day before -25,, i just let it run and cleared the code and it runs fine,,i won't keep buying $40 gm filters,and yes i do add ps
thanks,but what i'm trying to say is we don't need all these filters
i will pm you because i do need filters too though,,,i just think its a waste of time to replace them[fuel filters] everytime fuel gells,,i really think the ''ulsd'' diesel is the real problem[i don't think that there are the proper additives in it]i think we are getting screwed ,,i never have had a problem untill the[fuel companys] were forced by the gov to sell these fuels and ive driven diesel trucks for the past 20 years,,i'll bet i could get every gelled filter and use them and never have to replace those with a new store bought filter again
Mike:
I am just curious, do you run the front winter grill cover? It seems that lately, more problems are associated with water in the fuel rather that the fuel gelling. It could be a freezing problem with the fuel rather than a gelling problem. If you are not running the front grill cover, you should try it. Don't worry about overheating, as the 2006's cool very well.
I hear what your saying about the snow, and I remember a year or so ago, there was a lot of problems associated with snow buildup under the fenders and causing havoc. Maybe your MAF or MAP sensors froze up from the snow? Just a thought. GM was aware of this issue, and I think put out a TSB on it.
Don't get down on these trucks, as they are still the best out there! Be positive.
Supposed to be cut 50% here too... Tell that to all the guys sitting on the side of the road today. I believe that might be why Pilot locked out their pumps last night... At least I don't feel like the Lone Ranger
That's exactly what I was going to suggest. But isn't his inside his tranny?May be a dumb question but I know NSBU switches can freeze or ice up and throw all kinds of crazy codes. I have no idea though if they still use those in the newer generation trucks though.
Inside? Really... I didn't know that. Didn't slide under there to look at it today. The shop floor is so full of crap and slushy stuff from the weather lately I decided to wait until it dries and I could sweep it down first. The explanation on the P0700s coincides with the 2 x it went into limp then. If nothing else, the education on these trucks continues...That's exactly what I was going to suggest. But isn't his inside his tranny?
The p0700 is just the tcm telling the ecm to light the cel. And the u0100 is just a comm problem I think. So it could still be a loose/dirty connection to the trans.
That clears that up...The NSBU is inside the trans on the 06+. There's a pic of the selector shaft in my garage.
