The factory line worker, boring job BTW, is doing a crossword puzzle with their other hand while dropping the pistons in. A hand built engine would cost more than the vehicle new: see race car engine prices.
I have 36K extreme miles on gapless rings and still no blowby. I have extended my oil drain intervals to 5000 miles. Formerly 3000 miles was too many miles per UOA. I can see the marks on the dipstick awhile after an oil change. The marks start to go away near 5K miles: what oil looks like after startup without gapless rings. The project 6.5 truck has 1000 miles with gapless rings.
It's important to get a good seat of the rings from the word go. Stomp it, but, vary the load and RPM. You need full throttle ASAP to seat the 2nd ring, but, not extended time at full throttle. Seen several ring sets that didn't fully seat the 2nd ring.
So I haven't broken my engine with them in. What more do you need for proof there isn't a downside?
They take longer to install and are "new" with some shops afraid of them (the unknown).
@MrMarty51 Total Seal "If you have any questions about how your cylinder should be honed, please contact us at 800-874-2753" Unless you are dropping them in an Optimizer or P400, used or new, the (any) machining cost on a GM casting isn't worth it plus OS piston cost. They run just fine with a hand drill and stone set. Just have to break the glaze. Used the hand drill on both of my gapless ring installs both perfect bores and highly questionable. YMMV as you may know a machinist that will work for beer. I don't.
I sure wish that I did know a machinist like that.
Only one local shop that will bore cylinders and fit pistons. So much for every 0.010 over bore.
He might though, cut a deal if I fit the pistons, using His tooling.
the local college would do it too, for free, if they were in the engine rebuilding stages of the classes.
So, it would probably be wise to get the Optimizer or the P400 rather than spend money on the stock GM block and heads, i`m guessing.
Are the gapless rings doing more than making you feel better by having prettier oil?
The lack of blowby is pretty big. The rings go away before anything else on these engines. (Aside of cracks or head bolt/gasket failures.) This is one well known item to check the health of the engine before buying one.
IMO you are missing the point of "prettier oil". Doubling the miles I get out of oil before soot ruins it to a thicker grade is a verified proof of less blowby and all the garbage in the combustion chamber getting past the ring gap into the crankcase. Small NA precups and all the fuel I can throw at it from a stock IP in hot thin air should add more of a "wow" factor for as dirty as this engine runs. (Our IDI 6.2-6.5 engines are fairly dirty to begin with having a 2500 mile oil change in the owners manual. ) Some days Patch actually fails emissions: the other days the soot blows out their sensors so bad they can't get a zero reading to officially fail it. I have been held up as they first retest other failed cars, from Patch being tested at the same time, then try and test Patch. I really need the smoke puff limiter... (Why they make one "snap" floor it when they only read the smoke at WOT Full RPM is plain stupid.) Regardless the high stall converter cleaned up the smoke a lot as I don't run the engine down low lugging smoke so much anymore.
More air kept in the combustion chamber means more power and less for the CDR system to choke the engine up on.
I have posted UOA results and the like in the above noted thread of mine. All this simply shows my experience with something new and improved for our forgotten diesels. Hopefully this gives you some better understanding for any decisions you may make or just discussion.
