matuva
Tropical 6.5er
I just received my set of rings, with n°2 gapless rings.
Thanks to Leroy who has been able to provide me very fast
Her is one set. You can see the stock n°2 ring machined, and the black ring which will transform the all thing in a gapless ring.
Ready to insert
Inserted.
Now, the question is: How do I have to install them:
I mean, what do I have to care about, as the black ones seem to be brittle. Should I add oil or some engine assy lube on the 2 rings?
If I look the piston from above, do I have to install the black one above, facing me?
or under, facing the rod?
Ready to insert
Inserted.
