luke22494
i tried a full os bump on my 94 a couple weeks ago and i drove it a couple miles like that. when i got back to the house my truck was loping. would a full os bump cause any problems with anything at all
lopey idle, touchy throttle, etc, a good tune is the best way to go
Actually you can adjust the bump to get rid of all most all off the problems it may cause at idle.I would suggest not going below 4 MM cubed at idle this generally leaves enough room for the computer to compensate for most idle irregularities. yet every truck is different based on how your pump was set up and how worn it is.
I have actually played with a reverse optic bump. Some interesting things these mechanical DS 4 with electronic control.
