Full LED's On My Truck Now
What's wrong with incandescence?
Are you going green? Or going blind?
Do you wish to make oncoming traffic blind?
Nope. LED's use Less Power, have a Sharper / Crisper Color, and just Look better than Halogen.
...and when Used in Brake / Turn Lights, they are Safer than Halogen.
My voltages very seldom get over 13.6.....if it is really cold outside, say 35* or so then my voltage will get over 14vdc. I am on my second altenator and the same thing happens....what PN# would you suggest when buying these....
I'm in if there a pretty good deal w/ Facebook. I want to start at the rear with reverse lights,flasher, and turn/tail/stops.
So, getting LEDs in the DRL's is a no-no? Or do I have to disable everything to use them?
No, I've had LED's in my DRL's pretty much since the Day I got the Truck. I went Back & Fourth between LED's & Halogen, but I've had LED's in there longer. No Problems at all. Just take out the Stock Bulb, and put in the LED.
Any idea of the bulb number? The fitment guide states 4114 and I haven't found anything on the v-led site. I just ordered amber front turns and front markers about 10 minutes ago. I should have waited...
3157 for the DRL, Running / Signal up Front, Back Up, and Stop / Turn in the Rear, it's all the same.
