Thanks Jim. I will just buy a new one to dig out the old fsd I have to take off the bottom intake its really tight in theRe if I go that far I might as well put on a new IP since everthing is apart anyway. That new #9 res where does it get pluged into?
Minor correction, OBD-II ko/ko or scan tool learn has to be initiated has to be done to notice a missing resistor or one who's value has been changed1994-1995 = OBD-I ... resistor is irrelevant for 50 starts or a TDLearn.
1996-2000 = OBD-II ... resistor difference is noticed immediately. Resistor absence usually results in a no-start.
If I recall correctly. You need to get a resistor. They can be fished out of the existing PMD on the 94s, not sure you have enough room on yours because of the dual thermostat x-over. Easier in any case to buy a new one.
Minor correction, OBD-II ko/ko or scan tool learn has to be initiated to notice a missing resistor or one who's value has been changed1994-1995 = OBD-I ... resistor is irrelevant for 50 starts or a TDLearn.
