Matt Bachand
Depends on the 6.5
My doors don't lock
Well I got the fuel tank switch valve out. In the process I took a Diesel bath. But, I got it out along with all the switch in the cab and all the wire. It started getting dark so I was unable to test it afterwords.
It only gets better! :thumbsup:
I also locked my keys in the truck. So the wife is mailing me the spare keys. I will be without a truck till the end of the week. Anybody know a way to break into a 1993 Chevrolet? :mad2:
Ok after attempting to get in my truck for over 2 hours I gave up and called a lock smith and $35 later I got into my truck. I then went and got a key made and a magnet key holder. So after about $40 I am good to go.
The good news is my bypass for the Diesel switch is not leaking and after removing all the excess wires my volt gauge is sitting higher than it was. So another plus on all of this work I have done.
If I get out of class early enough tomorrow I will re-test the fuel pressure on my truck and post it. :thumbsup:
Alright I finally got out of class early enough to play around with my truck.
I put the gauge back into the same exact spot as before. At idle the pressure went up to 2.5 psi. When I turned the truck off it went up to 5 psi. I did not manipulate it with the fuse like I did before. ):h
Thanksgiving weekend I will install the "T" in the valley between the filter manager and the injection pump.
I may start a new thread for that one! :thumbsup:
