3500GMC
What T F, over
bison he is (imo) discribing normal operating conditions with engine running. Except the vac/suction should stop at the discharge of the LP and become pressurized until IP.
Yep, gotcha.
....Unless I'm mistaken hence the reason for the subject line on the post...2 lines come out of the tank 1 feeds the LP the other is a bleed return, right? The return line was wet & weeping and had left some of under carriage in that area wet as well as the frame rail was wet with diesel.....
Yeah it sounds like you've got things fixed up. I wasn't sure if you had found and repaired the supply line instead of the return line. You would know.. You're the one wearing the diesel.. ha ha .,
